To build an executable or application on a Linux operating system, you must use LabVIEW Professional for Linux. This is because the Application Builder functionality is included with the Professional edition of LabVIEW.
If you are looking for the Linux Application Builder, it is not installed as a separate product. Instead, download and install LabVIEW Professional for Linux, then follow the Linux installation instructions provided by NI.
After installation, you should follow the same workflow used in Windows, for example, for creating an executable, you may create or open a LabVIEW Project, then right click on build specifications and select New >> Application.
Note: Although VIs can be moved between supported Windows and Linux installations of LabVIEW, a Windows installation of LabVIEW can only build executables for Windows. Likewise, executable builds for Linux must be created from a Linux installation of LabVIEW.
