Is the LabVIEW Lego® Mindstorms® Module Compatible with LabVIEW 2017 or Newer?
Updated May 30, 2025
  • LabVIEW for LEGO Mindstorms
  • LabVIEW 2016
When I install the NI LabVIEW Module for LEGO® MINDSTORMS® alongside LabVIEW 2017 or newer, it prompts me to install LabVIEW 2016. Is there a way I can develop my LEGO® MINDSTORMS® applications in LabVIEW 2017 or newer?
The most recent version of the NI LabVIEW Module for LEGO® MINDSTORMS® is compatible with LabVIEW 2016. Therefore, LabVIEW 2017 and newer cannot be used with the module.
To use the latest version of the module, you need to install LabVIEW 2016 and then install the LabVIEW 2016 Module for LEGO MINDSTORMS.
  • If you need to download LabVIEW 2016 with the associated serial number, register the serial number  to your NI User Account and then navigate to the download page.
Multiple versions of LabVIEW can be installed on the same computer. If you need support for MINDSTORMS and want to develop other applications with another version of LabVIEW, you can use LabVIEW 2016 exclusively for LEGO MINDSTORMS applications, and your desired version of LabVIEW for any other application. You will need SSP to get this software if you do not already have it.
