The download and installation method for LabVIEW Model Interface Toolkit is different for different versions of the software. See the instructions below for whichever version you would like to download. For complete software requirements please check the LabVIEW Model Interface Toolkit New Features and Changes section in the User Manual.
LabVIEW Model Interface Toolkit 2019 and Later
To install this toolkit, simply locate it in NI Package Manager as in the image below, or download it from the LabVIEW Model Interface Toolkit Download page.
LabVIEW Model Interface Toolkit 2018 SP1 and Earlier
In older versions of the software, the primary distribution method for the LabVIEW Model Interface Toolkit was through the VeriStand installer. Complete the below steps to install this toolkit:
- Launch the corresponding version of the VeriStand installer, which is available at both the VeriStand Download page and in the form of physical media.
- When the installer initializes, press Next.
- On the User Information step, select the Install NI VeriStand 20xx Evaluation - Serial number not required option, and press Next.
- On the Destination Directory step, make no changes and press Next.
- On the Features step, simply make the selections outlined in the image below to install the LabVIEW Model Interface Toolkit without installing VeriStand.
