How are I/O Pins on PCIe-6509 Configured?
Updated May 3, 2018
  • PCIe-6509
I want to configure the I/O pins on my PCIe-6509, but I don't know if the channels are individually configured or configured by port. I can't find this information in the datasheet.
The digital I/O pins on the PCIe-6509 are configured individually.
The following example shows how individual lines of a port can be inputs and outputs
To configure a entire port, you should use the following syntax:
