Linux RT Target Installation Failed When Reinstalling Software in MAX
Updated Dec 22, 2023
  • cRIO-9068
  • cRIO-9066
  • cRIO-9038
  • cRIO-9039
  • sbRIO-9637
  • CVS-1459RT
  • IC-3172
  • NI-RIO
  • NI CompactRIO
  • NI-IMAQdx
  • NI Linux Real-Time
Other
This can occur on remote targets running NI Linux Real-Time OS.
I am trying to install or reinstall a certain piece of software onto my NI Linux Real-Time target using NI Measurement and Automation Explorer (MAX), but I received the following error:
Installation failed while transferring files to the remote host. Either the disk on the remote host has become damaged or your software installation is corrupt.
In addition, the controller shows up as 'Disconnected' in NI-MAX, and information such as physical memory and disk capacity are unavailable.
  1. Run the script in the target located at /usr/local/bin/updateNIDrivers
  2. Alternatively, consult the manual of your device and reboot it into safe mode
  3. Reformat/Uninstall software on the target, before attempting to reinstall software
If the procedure above does not work, you can try following the procedure on Resetting the Password for NI Real-Time Targets.
This problem is related to a known issue with NI-KAL, the kernel abstraction layer on NI Linux RT targets. The issue occurs when NI-KAL based drivers do not properly rebuild driver dependencies during the reinstall process.
One example is observed if your NI Linux RT target already has NI-DAQmx and NI-IMAQdx installed, and you attempt to reinstall NI-IMAQdx.
Note: Only controller using Linux Real-Time operating systems are affected by this issue. To verify the OS that get's used on a specific controller see Real-Time Controllers and Real-Time Operation System Compatibility for more infomration.
