Cannot Add Date/Time Column to MySQL Database Using Database Connectivity Toolkit
Updated Jul 11, 2023
  • LabVIEW 2017 Professional
  • LabVIEW 2016 Professional
  • LabVIEW 2015 SP1 Professional
  • LabVIEW Database Connectivity Toolkit
  • LabVIEW 2017 Database Connectivity Toolkit
  • LabVIEW 2016 Database Connectivity Toolkit
  • LabVIEW 2015 SP1 Database Connectivity Toolkit
I'm using Database Connectivity Toolkit to write data to a MySQL database from LabVIEW. I need to create a table containing a column of date/time datatype, thus I used DB Tools Insert Data VI  (setting create table? input to True) to create the table and DB Tools Format Datetime String VI to return a date/time string to be written to the database:
However, after executing the VI, the table created in the MySQL database only contains the date information and not time information.
Creating the table using DB Tools Create Table VI leads to the same problem.
This is a known issue in LabVIEW 2015 and later identified with ID #575865, which is currently under investigation.
As a workaround, you can:
  1. Create the table using DB Tools Create Table VI  or DB Tools Insert Data VI  (setting create table? input to True) without the date/time column
  2. Use DB Tools Execute Query VI function to add a column of the correct date/time type to the table
Alternatively, you can also directly create the table with the correct date/time column though SQL query, using DB Tools Execute Query VI function, as shown below:
You can search for the known issue ID provided above in the readme of future LabVIEW versions to check if it has been solved.
The Database Connectivity Toolkit is included in LabVIEW Professional 2014 and later.
