National Instruments sells
CAN cables of 1m and 2m length.
If you need longer cables for your application, confirm with the NI product documentation for your device, the XNET Manual, and/or the SAE J2411 or ISO 11898, CiA DS 102, and DeviceNet specifications. You may need to create your own cable or purchase from a third party. National Instruments cannot guarantee your application will work outside of the cables NI sells.
Specific information for Cable Length and Requirements for a National Instruments product can be found the Getting Started Guide and/or User Manual of the specific product. For example, for the NI 9862, the Getting Started Guide has a section for
Cabling Requirements for the NI 9862.
