The SensorDAQ is a USB data acquisition module sold by Vernier that uses the NI-DAQmx driver and National Instruments LabVIEW.
The official
Vernier SensorDAQ® page has links to the SensorDAQ® driver, example programs, and a readme file. The SensorDAQ® driver must be installed to use the device with Vernier sensors.
In order to use the SensorDAQ® with LabVIEW, the following requirements must be met:
- LabVIEW 2009 or newer
- NI-DAQmx and SensorDAQ® driver
- Windows 2000 or newer
- A USB port
The SensorDAQ® screw terminal connector can be accessed using DAQmx without needing Vernier's SensorDAQ® driver. The screw terminal connector contains 2 analog input channels, 4 digital I/O lines, 1 analog output channel, and 1 counter.
The Vernier SensorDAQ® is not compatible with
Vernier Logger Pro® software.
