How to Use Vernier SensorDAQ® with LabVIEW and DAQmx
Updated Dec 28, 2023
  • Vernier SensorDAQ
  • LabVIEW Base
Other
Vernier SensorDAQ®
I have the Vernier SensorDAQ®.  Does this device work with NI LabVIEW?
The SensorDAQ is a USB data acquisition module that was sold by Vernier that uses the NI-DAQmx driver and NI LabVIEW. It is no longer sold by Vernier.
The official Vernier SensorDAQ® page has links to the SensorDAQ® driver, example programs, and a readme file. The SensorDAQ® driver must be installed to use the device with Vernier sensors.
In order to use the SensorDAQ® with LabVIEW, the following requirements must be met:
  1. LabVIEW 2009 or newer
  2. NI-DAQmx  and SensorDAQ® driver
  3. Windows 2000 or newer
  4. A USB port
The SensorDAQ® screw terminal connector can be accessed using DAQmx without needing Vernier's SensorDAQ® driver. The screw terminal connector contains 2 analog input channels, 4 digital I/O lines, 1 analog output channel, and 1 counter.
The Vernier SensorDAQ® is not compatible with Vernier Logger Pro® software.
