DAQExpress is free companion software that is included with select NI data acquisition hardware, such as USB and PCI Express DAQ devices.
You can access the DAQExpress software online only through the
NI Package Manager (NIPM).
Before you begin, please make sure you have:
- already installed the supported version of the NI DAQmx driver before using DAQExpress, you can check the supported version of DAQExpress under Application Software Support in the NI DAQmx readme page.
- a supported device for DAQExpress even if they are listed as supported under DAQmx. You can find a list of supported hardware in the DAQExpress Manual.
Warning: Installing NIPM replaces the NI Uninstaller. This means you can only uninstall NI software through NIPM. NIPM does not allow you to modify existing software installations, so that capability will be lost when you install it.
