Il contenuto non è disponibile nella lingua selezionata.
Verrà mostrato il contenuto in un'altra delle lingue disponibili. Il tuo browser potrebbe avere delle funzionalità di traduzione.
Front Panel Fonts are the Wrong Size on My Real-Time Target When Deployed From LabVIEW 2016
Updated Nov 8, 2022
  • cRIO-9030
  • LabVIEW 2016 Real-Time Module
  • NI Linux Real-Time
When deploying a VI to a Real-Time (RT) target, my text doesn't display the font size on the Real-Time device the same way as it does on my development system. How can I fix the font sizes?
Fonts are not correctly installed initially on the LabVIEW RT 2016 Embedded UI. Therefore, to properly install the fonts, run the following command from the shell with administrative privileges.
  1. Access the shell on your Real-Time device using an administrator account
  2. Enter the following shell command:
    find /usr/share/fonts/X11 -type d -print0 | xargs -0 mkfontdir
After running the command, restart the target and the fonts will display properly.
Reformatting the target will require you to run the command again after software is reinstalled to the target.
