Why Can I Only Use Up to 2m In Cabling on the 9402?
Updated Nov 5, 2017
  • NI-9402
The datasheet for the 9402 states that the maximum cable length that you can use with the module is 2 meters. Why is this the limit?
National Instrument only tests up to this measurement of cabling length and insures what all specifications will be met under this condition. Introducing longer cabling would cause additional I/O propagation delays and theĀ specification for this would not be met.
