How to Make Larger Font Sizes of Labels in a VI
Updated Aug 22, 2023
  • LabVIEW 2014 Base
I want to increase the font size of the labels in my VI. I have selected the maximum font size, 36 pt, in the Application Font drop down. How can I make the font even larger?
Even though 36 pt. font is the largest option in the Application Font drop down, you can still type the desired font size by performing the following steps.
  1. Select the text that you would like to enlarge.
  2. Go to the Font Dialog window by navigating to Application Font ยป Font Dialog...
  3. Manually type in the desired font size:
Do not increase the font size to be excessively large (i.e. 9000 pt. font). Doing this may potentially harm the performance of LabVIEW.
