Volume Licensed LabVIEW 2017 Splash Screen Displays Unregistered
Updated Nov 9, 2017
  • LabVIEW 2017 Base
Other
This usually occurs when LabVIEW 2017 is installed via the Volume License Installer.
When launching software installed via Volume License Installer, the splash screen displays "Unregistered".
This behavior is cosmetic, and does not affect the licensing and execution of LabVIEW. To remove it, follow the steps below
  1. Open NI License Manager
  2. Initiate the activation of any NI software
  3. Log into your NI.com account when prompted
  4. Exit the activation process while remaining logged in
This occurs because NI License Manager does not prompt the user the log in, when installing via Volume License Installer. NI Software uses the NI License Manger API to obtain user information. Thus, if this field is not populated, the value "Unregistered" is displayed instead.
