The default setting of DAQ Assistant Express VI is 10 seconds, but you may change the Timeout in the following 2 ways:
- Change this value in the Advanced Timing tab of the DAQ Assistant window.
You can programmatically set the timeout value using the Timeout (s) input of the DAQ Assistant .
Earlier versions of DAQmx (7.x) do not allow you to set a timeout value. Finite and continuous acquisitions/generation tasks have an infinite timeout, and single-point input/output has a 10 second timeout. If you need to set a timeout, either upgrade to a later version of DAQmx (8.x or later) or use the NI-DAQmx VIs. You can use the DAQmx Read VI to specify a timeout value.
Refer to the LabVIEW Help for the DAQ Assistant Express VI for more information. You can access the help for a VI by right-clicking it on the block diagram and selecting
Help from the shortcut menu.
