Inconsistent Open Thermocouple Channel Readings in Scan Engine Mode
Updated Dec 5, 2017
  • NI-9214
  • cRIO-9037
  • NI-RIO
  • NI CompactRIO
Other
C Series modules that have Open Thermocouple Detection (OTD)
I have a module that has the Open Thermocouple Detection function. When measuring channels with an open thermocouple connection, depending on which method I'm using, I get different values. What is the reason for this?
This is an expected behavior due to different front-end scan interface reading methods. The values returned can be either 0 or full scale positive reading of the selected thermocouple type.
It is not recommended to use this value as a means to detect an open thermocouple connection. As 'Error -65582: An open thermocouple was detected' is always returned regardless of which method is used, it is recommended that you handle this error as a means of detecting an open thermocouple instead.
