Software Needed to Use a myRIO
Updated Aug 5, 2026
  • myRIO-1900
  • myRIO-1950
  • NI-RIO
  • Do I need to install any of the RIO Drivers?
  • What is the minimum software that I need on my computer?
The corresponding myRIO Toolkit will bring the needed drivers to recognize and program the device, thus you don’t need to install the RIO drivers. A RIO component will show up on NI MAX after installing the myRIO Toolkit.
In order to program your myRIO device the minimum software that needs to be installed is:  Note: If you plan to use the onboard FPGA on the device, you will need LabVIEW FPGA  and the Compilation Tools for Vivado installed.
If you plan to deploy an executable to a target computer that communicates with a myRIO over USB, then you should install the latest version of the CompactRIO Runtime on the target computer. This allows the target computer to recognize the myRIO and create a virtual network connection. CompactRIO Runtime should show up as one of the additional installers you could include when creating an installer to deploy using the build specifications.
Note: When programming the myRIO using C/C++, LabVIEW and LabVIEW RealTime are not needed.
The optional software components typically used with the myRIO are:
  • LabVIEW Robotics Module for LabRIO
  • VI Package Manager
  • Vision Acquisition Software
  • Vision Development Module
