This error occurs when running a DAQmx task or a Test Panel from Measurement & Automation Explorer (MAX). To fix it, try the following:
These errors are often associated with an incorrect file or dependency in your machine. There is a chance that the VI, project, or software in use has become corrupted. Also, make sure the device is connected properly and you can see it in NI MAX. Refer to LED Behavior on my USB DAQ and My NI USB Device Shows as a USB-RAW Device in NI-MAX on a Windows Machine.
