Installer Fails to Build Due to NI Atomic PXIe Peripheral Module Driver
Updated Oct 31, 2019
  • NI-Serial 17.0
When I try to build an installer from my successfully built executable (EXE) that uses NI-Serial 17.0, I get the following error:
CDK_Build_Invoke.vi.ProxyCaller >> CDK_Build_Invoke.vi >> CDK_Engine_Main.vi >> IB_MSI.lvclass:Build.vi >> IB_MSI.lvclass:Engine_Build.vi >> NI_MDF.lvlib:MDFBuildDist_Build.vi
The following errors and warnings were recorded during the build:
Error:
An internal tool or library returned an error.
Details:
Error Messages
Error: Part at path "c:\programdata\national instruments\mdf\productcache\ni atomic pxie peripheral module driver [17.00.49152]\niapxipmi.msi" was included by 2 products: 'NI Atomic PXIe Peripheral Module Driver' and 'NI Atomic PXIe PeripheralModule Driver'
Code:
-21
Navigate to and delete this file:
C:\Program Files (x86)\National Instruments\Shared\MDF\Manifests\NI Atomic PXIe Peripheral Module Driver {5A5B4FB4-BC1E-44FF-BF12-78463A63C732}.xml
Once deleted, the installer will build successfully.
This issue occurs if NI-Serial has been installed through NI Package Manager (NIPM), a deployment created, and then NI-Serial is installed again from the online download page.
