NI-XNET Internal Error 0xBFF63001 with Self-Test in NI MAX
Updated Sep 27, 2023
  • C Series CAN Interface Module
  • PXI CAN Interface Module
  • NI-XNET
I tried to self-test my PXI-8512 XNET card in NI Measurement & Automation Explorer (NI MAX) and I got the following error:
The self test failed.
NI-XNET: (Hex 0xBFF63001) An internal error occurred in the NI-XNET driver. Please contact National Instruments and provide the information from the file %LOCALAPPDATA%\National Instruments\NI-XNET\log\niXntErr.log. On Windows XP, the file can be found at %USERPROFILE%\Local Settings\Application Data\National Instruments\NI-XNET\log\niXntErr.log. Please note that this location may be hidden on your computer.
Try the following troubleshooting steps, and see if the behavior persists:
  • Remove and replace the module or card in the chassis
  • Reset, or power cycle the chassis
  • If the behavior is on a occurring on a cRIO, try compiling and running a blank FPGA VI on the chassis prior to self testing.
If you are starting and stopping sessions asynchronously:
XNET Stop will stop a session first, and then try and stop the interface if it is not being used by another session. If you are starting and stopping sessions asynchronously, different processes could cause the firmware to behave unexpectedly or enter a bad state. Once the firmware is in a bad state, the system API will not be able to communicate with it and will re-assign the interface of a default name of "CAN-1" which will cause further internal errors.
