How Can I Change the Action of TestStand Depending on the Result?
Updated Oct 19, 2024
  • TestStand
  • I want to be able to skip or jump to a specific step from my sequence based on a condition, for example, if any or a specific run-time error occurs.
  • Can I skip to a specific step inside of a TestStand sequence, even if the step is in a step group that has already executed?
  • I only want to run a step if a particular test, or group of tests, passes or fails
  • I want to end the MainSequence based on the results of a SubSequence, how can i do this?
There are a number of tools within TestStand that allow you to programmatically control the flow of steps depending on results, variable values or other conditions. Below are listed the fundamental tools used to control the flow:
Post-Actions
You can use the Post Actions of any step and / or a Goto step type allow to jump to another step in a sequence.
  • Select a step and navigate to Step Settings and select Post Actions
  • In a Goto step, simply choose the desired step from the drop-down labeled Destination Step.
  • In the Post Actions of a normal step you can check the Use Custom Condition box and then choose Goto Step from the drop down under the On Condition True or On Condition False section, you may choose different steps depending on the step result (the default condition is pass or fail). Then, you can choose your destination step from the second drop-down in the section you chose.
For example, you can check the value of the Step.Result.Error.Code property of any step and jump to a specific step  if a specific run-time error occurs, or the Step.Result.Error.Occurred property instead for any run-time error.
Normally this process allows you to only go to any step in the current, or next step group, but not to a previous step group.  However you can use the RunState.NextStepIndex and RunState.StepGroup properties to jump to a previous step group. RunState.NextStepIndex contains the zero-based index of the desired step that follows the currently executing step in the step group indicated by RunState.StepGroup. By modifying the value of these properties, you can specify the step that TestStand executes next. For example, if you are in the Main step group and you want to make TestStand jump to the first step in the Cleanup sequence, you can have the following expression in a Statement step:
RunState.NextStepIndex = 0, RunState.StepGroup = "Setup"
The valid values for the RunState.StepGroup property are: SetupMain and Cleanup.
Preconditions
You can use Precondition to only allow a step to run if a certain condition has been met, for example, a test must have passed, or failed or executed to run.
  • Here you could choose to only run if a known variable was equal to a specified value.
  • Alternatively you can use the Precondition Builder.  (shown in image below)
    • This allows you to more easily define your condition and insert new expressions dependent on the result/state of specified steps.
Flow Control Steps
These steps are available from the Flow Control folder of the Step Types in the Insertion Palette (Shown in Image below).
The steps enable users to add conditions the program and enable coding functions such as If, Else, Else If, While and For.
Similar to the Preconditions, the condition builder is available to assist in the building of the expression that will be used to control the flow.
The Post Action method can be combined with the SequenceFilePostStepRuntimeError Engine Callback for more flexible approaches. Refer to Handling TestStand Runtime Errors  and the Overriding SequenceFilePostStepRuntimeError Callback TestStand  shipping example for more information about the SequenceFilePostStepRuntimeError Engine Callback.
This solution doesn't work for versions prior to TestStand 2.0.
