Newer NI PXIe controllers typically can have 64 devices and 128 endpoints. However, some controllers, especially older ones, only allow for 32 devices and fewer than 127 endpoints. You can use 3rd party tools to see how many devices and endpoints are being used, such as USB Device Tree Viewer. Note that NI does not endorse or maintain this tool. If your device has USB 3.0 ports, additional USB 2.0 ports may appear in the USB Device Tree Viewer, as they are used by the controller to manage the USB 2.0 devices plugged into the USB 3.0 port. These are internal and not user accessible.
If you wish to add more USB host controllers to your PXIe System, you can do so via a PXIe-1095/1092/1084 Chassis (Timing and Sync Variant) or via a 3rd party PXIe USB card. If your PXIe controller has a Thunderbolt (TBT) port, you can add another USB Controller via a TBT dock. This will not work if you use a USB-C hub, which will function as a standard USB hub instead of adding another USB Controller.
