This may occur due to a Windows setting called USB selective suspend. By default, this setting is enabled. When enabled, it cuts power to idle USB devices in order to conserve power.
This setting can be disabled through Performance Settings as follows:
- Go to Power Options via: All Control Panel Items » Power Options » Edit Plan Settings:
 - Select Change advanced power settings.
 - Expand the USB Settings tab and disable USB selective suspend settings:
Some non-isolated devices may exhibit this issue if their ground is not at the same potential as the computer's power supply ground or if transients or excessive noise is introduced to the device, causing disruptions to the USB communication. To mitigate this, follow the guidelines in the Field Wiring and Noise Considerations for Analog Signals article.
