Can a PXI or cRIO be used as an EtherCAT Slave?
Updated May 21, 2020
  • NI-9144
  • NI-9145
  • cRIO ECAT S
Other
CompactRIO (cRIO), PXI, PXIe, EtherCAT, Windows PC
I want to use my real-time system (CompactRIO, PXI, PXIe) as an EtherCAT slave. Is this possible?
It is not currently possible to use a PXI or a cRIO chassis as an EtherCAT slave.
There are a few options that are possible to use for an EtherCAT slave
EtherCAT slave interfaces require special circuitry to operate properly, as well as licensing through the EtherCAT consortium.
