Missing VIs: Read Delimited Spreadsheet File and Write Delimited Spreadsheet File
Updated May 3, 2018
I'm missing a couple VIs from the File I/O Palette, specifically Read Delimited Spreadsheet File and Write Delimited Spreadsheet File.
Double check that you are opening your project in the correct version of LabVIEW. This often happens when you write a VI in 64-bit LabVIEW and open it in 32-bit LabVIEW.
