If you would simply like to know who how many users are currently configured as having access to a test station and display a pop-up containing this information, you can refer to
Popup List of Users on Test Station Community Example.
You can also place
GetPropertyObjectByOffset method in a loop, incrementing the offset parameter at each iteration of the loop, in order to loop though the entire array of users.
