此內容不適用於您所偏好的語言。
此內容已顯示為其他適用語言。 您的瀏覽器可能含有可協助翻譯的套件。
Correct Location on Disk to Store a .icd Camera File to Use with NI-IMAQ
Updated Apr 1, 2026
  • NI-IMAQ
I recently downloaded a camera file from NI's website or generated one from the Camera File Generator. Where do I need to place the *.icd file so I can configure my camera and my IMAQ hardware in Measurement & Automation Explorer (MAX)?
Once you download or generate (Creating a Camera File using the NI Camera File Generator) the appropriate camera file for your camera, the location of the *.icd file will depend on which version of Vision Acquisition Software you have installed:
  • Vision Acquisition Software 8.2.3 and later:
    • If you are using Windows Vista or Windows 7/8/10/11, place the *.icd file in
<Users>\Public\Public Documents\National Instruments\NI-IMAQ\Data
  • If you are using Windows XP, place the *.icd file in
<Documents and Settings>\All Users\Shared Documents\National Instruments\NI-IMAQ\Data
  • Vision Acquisition Software 8.2.3 and Earlier place the *.icd  file in:
<National Instruments>\NI-IMAQ\Data
 Once the file is placed in the correct directory, launch MAX and select your IMAQ (i.e., PCIe-1433) device from the Devices and Interfaces. With your IMAQ device highlighted, right-click the camera and select Camera Selection from the context menu. Select the appropriate camera file from the list.
After your camera file is loaded, refer to Measurement & Automation Explorer Help for NI-IMAQ (from the Help drop down menu in MAX, select Help Topics»NI-Vision»NI-IMAQ) for more information on configuring your particular type of camera with your specific IMAQ hardware.
