主页
技术支持
NI-IMAQ和视觉采集软件(VAS)安装了哪些VI?
更新 Dec 6, 2019
驱动
Vision Acquisition Software March 2010
NI-IMAQ
如果我只安装NI-IMAQ驱动程序而不安装视觉开发模块(VDM),LabVIEW中会有哪些VI?
NI-IMAQ作为
视觉采集软件(VAS)驱动包
的一部分,在安装高层和底层相机控制VI的同时,也有一些用于图片处理,管理和存盘,图片显示和操作的非驱动VI。NI-IMAQ 4.0驱动提供的VI完全列表如下所示。所有VI均位于视觉(或者视觉与运动)板块。完全列表也可通过选择LabVIEW里
Help » NI-IMAQ VI Reference...
获得。
NI-IMAQ调色板
IMAQ 拜耳颜色解码 (IMAQ Bayer Color Decode)
IMAQ 关闭 (IMAQ Close)
IMAQ 创建拜耳LUT (IMAQ Close)
IMAQ 连续采集 (IMAQ Grab Acquire)
IMAQ 连续采集设置 (IMAQ Grab Setup)
IMAQ 初始化 (IMAQ Init)
IMAQ 序列 (IMAQ Sequence)
IMAQ 抓取 (IMAQ Snap)
属性节点(Property Node)
相机控制子调色板
IMAQ 获取相机属性 (IMAQ Get Camera Attribute)
IMAQ 串行读取 (IMAQ Serial Read)
IMAQ 串行读取字节 (IMAQ Serial Read Bytes)
IMAQ 串行写入 (IMAQ Serial Write)
IMAQ 设置相机属性 (IMAQ Set Camera Attribute)
低级采集子调色板
IMAQ 配置缓冲区 (IMAQ Configure Buffer)
IMAQ 配置列表 (IMAQ Configure List)
IMAQ 复制获取缓冲区 (IMAQ Copy Acquired Buffer)
IMAQ 提取缓冲数据 (IMAQ Extract Buffer)
IMAQ 适合感兴趣区域 (IMAQ Fit ROI)
IMAQ 获取缓冲区 (IMAQ Get Buffer)
IMAQ 设置用户查找表 (IMAQ Set User LUT)
IMAQ 开始 (IMAQ Start)
IMAQ 状态 (IMAQ Status)
IMAQ 停止 (IMAQ Stop)
信号I / O子调色板
IMAQ 配置触发3 (IMAQ Configure Trigger3)
IMAQ 生成脉冲3 (IMAQ Generate Pulse3)
IMAQ 发生配置2 (IMAQ Occurrence Config2)
IMAQ 重置编码器位置 (IMAQ Reset Encoder Position)
IMAQ 触发驱动2 (IMAQ Trigger Drive2)
IMAQ 触发读取2 (IMAQ Trigger Read2)
IMAQ 触发路由2 (IMAQ Trigger Route2)
IMAQ 等待信号2 (IMAQ Wait Signal2)
Vision Express调色板
视觉采集 Express (Vision Acquisition Express)
Vision Utilities Palette
Color Utilities子调色板
IMAQ 彩色图片转数组 (IMAQ ColorImageToArray)
IMAQ 数组转彩色图片 (IMAQ ArrayToColorImage)
外部显示子调色板
IMAQ 构造感兴趣区域 (IMAQ ConstructROI)
IMAQ 获取调色板 (IMAQ GetPalette)
IMAQ 窗口背景 (IMAQ WindBackground)
IMAQ 关闭窗口 (IMAQ WindClose)
IMAQ 窗口映射显示 (IMAQ WindDisplayMapping)
IMAQ 窗口绘图 (IMAQ WindDraw)
IMAQ 窗口去除感兴趣区域 (IMAQ WindEraseROI)
IMAQ 窗口获取感兴趣区域 (IMAQ WindGetROI)
IMAQ 窗口格点 (IMAQ WindGrid)
IMAQ 窗口最后一个事件 (IMAQ WindLastEvent)
IMAQ 移动窗口 (IMAQ WindMove)
IMAQ 不拆分窗口 (IMAQ WindNonTearing)
IMAQ 窗口感兴趣区域颜色 (IMAQ WindROIColor)
IMAQ 设置窗口感兴趣区域 (IMAQ WindSetROI)
IMAQ 窗口设置 (IMAQ WindSetup)
IMAQ 窗口显示 (IMAQ WindShow)
IMAQ 窗口尺寸 (IMAQ WindSize)
IMAQ 关闭窗口工具 (IMAQ WindToolsClose)
IMAQ 移动窗口工具 (IMAQ WIndToolsMove)
IMAQ 选择窗口工具 (IMAQ WindToolsSelect)
IMAQ 设置窗口工具 (IMAQ WindToolsSetup)
IMAQ 显示窗口工具 (IMAQ WindToolsShow)
IMAQ 窗口大小 (IMAQ WindZoom)
文件子调色板
IMAQ 获取文件信息 (IMAQ GetFileInfo)
IMAQ 加载图像对话框 (IMAQ Load Image Dialog)
IMAQ 阅读图像和视觉信息 (IMAQ Read Image and Vision Info)
IMAQ 读取文件 (IMAQ ReadFile)
IMAQ 写文件2 (IMAQ Write File 2)
IMAQ 写字符串 (IMAQ Write String)
AVI子调色板
IMAQ AVI关闭 (IMAQ AVI Close)
IMAQ AVI创建 (IMAQ AVI Create)
IMAQ AVI获取过滤器名称 (IMAQ AVI Get Filter Names)
IMAQ AVI获取信息 (IMAQ AVI Get Info)
IMAQ AVI打开 (IMAQ AVI Open)
IMAQ AVI读帧 (IMAQ AVI Read Frame)
IMAQ AVI写帧 (IMAQ AVI Write Frame)
图像管理子调色板
IMAQ 创建 (IMAQ Create)
IMAQ 处置 (IMAQ Dispose)
IMAQ 拼合图像选项 (IMAQ Flatten Image Options)
IMAQ 将图像转为字符串 (IMAQ Flatten Image to String)
IMAQ 获取自定义密钥 (IMAQ Get Custom Keys)
IMAQ 获取图像信息 (GetImageInfo)
IMAQ 获取图像尺寸 (GetImageSize)
IMAQ 图像位深度 (IMAQ Image Bit Depth)
IMAQ 读取自定义数据 (IMAQ Read Custom Data)
IMAQ 远程显示选项 (IMAQ Remote Display Options)
IMAQ 删除自定义数据 (IMAQ Remove Custom Data)
IMAQ 设置图像尺寸 (IMAQ SetImageSize)
IMAQ 写入自定义数据 (IMAQ Write Custom Data)
叠加子调色板
IMAQ 清除覆盖 (IMAQ Clear Overlay)
IMAQ 复制覆盖 (IMAQ Copy Overlay)
IMAQ 合并覆盖 (IMAQ Merge Overlay)
IMAQ 曲线覆盖 (IMAQ Overlay Arc)
IMAQ 覆盖位图 (IMAQ Overlay Bitmap)
IMAQ 覆盖线 (IMAQ Overlay Line)
IMAQ 覆盖多行 (IMAQ Overlay Multiple Lines)
IMAQ 覆盖椭圆形 (IMAQ Overlay Oval)
IMAQ 覆盖点 (IMAQ Overlay Points)
IMAQ 覆盖矩形 (IMAQ Overlay Rectangle)
IMAQ 覆盖感兴趣区域 (IMAQ Overlay ROI)
IMAQ 覆盖文字 (IMAQ Overlay Text)
IMAQ 读取图像和视觉信息 (IMAQ Read Image and Vision Info)
IMAQ 写入图像和视觉信息 (IMAQ Write Image and Vision Info)
IMAQ 获取覆盖属性 (IMAQ Get Overlay Properties)
IMAQ 设置覆盖属性 (IMAQ Set Overlay Properties)
像素处理子调色板
IMAQ ImageToArray ** (图像转为数组)
IMAQ ArrayToImage ** (数组转为图像)
Vision RT
IMAQ RT视频输出 (Vision RTIMAQ RT Video Out)
IMAQ 视频输出显示 (IMAQ Video Out Display)
**自2010年驱动程序版本起,这些VI已添加到
视觉采集软件(Vision Acquisition Software)
中。
相关信息
注意:
上面没有列出与NI-IMAQdx驱动程序(也是Vision Acquisition Software的一部分)相关的VI。如果安装了NI-IMAQdx驱动程序,它将在视觉(或视觉与运动)调色板中创建一个NI-IMAQdx调色板
有关保存采集图像的更多信息,请参阅
不使用视觉开发模块保存NI-IMAQ图像
。如果您不希望创建自己的图像处理功能,这些功能可以在已转换为阵列的IMAQ图像上运行,NI仪器
视觉开发模块
可提供高级机器视觉和图像处理功能。
相关链接
在LabVIEW缺少NI-IMAQ或NI-IMAQdx函数面板
其他支持选项
询问NI社区
在我们的论坛中与其他用户协作
搜索NI社区以寻求解决方案
请求工程师的支持
可能需要有效的服务协议,支持选项因国家/地区而异。
打开服务请求
购买或续订支持服务
