NI-IMAQ, part of the Vision Acquisition Software driver package, installs VIs that allow for high-level and low-level camera control, as well as some non-driver VIs for image handling, managing images and saving them to disk, displaying images, and adding overlays. A full list of VIs installed with the NI-IMAQ 4.3 drivers is provided below. All VIs are found under the Vision (or Vision & Motion) palette. A full list can also be obtained by choosing Help»NI-IMAQ VI Reference... in LabVIEW.
**These VI's were added to Vision Acquisition Software as of driver version 2010.
Note: None of the VIs that are exclusively associated with the NI-IMAQdx driver (which is also a part of Vision Acquisition Software) are listed above. If the NI-IMAQdx driver is installed, it will create an NI-IMAQdx palette within the Vision (or Vision & Motion) palette For more information on saving an acquired image, please see Save NI-IMAQ Images Without Using Vision Development Module. If you do not wish to create your own image processing functions which operate on IMAQ images which have been converted into arrays, the National Instruments Vision Development Module provides high-level machine vision and image processing functions.
