Real-Time Features Not Available For My Real-Time Target in LabVIEW Project
Updated Sep 1, 2026
  • CompactRIO Controller
  • myRIO-1900
  • myRIO-1950
  • LabVIEW Real-Time Module
  • License Manager
  • Volume License Manager
I created a new project in LabVIEW and added my NI Linux Real-Time (RT) target to it.  However, after completing this process a "features not available" message is displayed next to the target. Furthermore, I cannot see Connect and Disconnect options when right-clicking on the controller. Please refer to the image below for more information:
Additionally, if I try to run a VI under my RT controller, the operation fails during the deployment process with the following error message:
NI System Configuration: The operation failed because of missing dependency items.
This image shows the error related to the NI System Configuration software when trying to run a VI on a NI Linux RT controller
This behavior may be observed when working with NI Linux RT controllers in LabVIEW, if the software required to program your RT target is not installed and activated on your computer. Follow these steps to troubleshoot this message:
Note: Some features of the LabVIEW Real-Time Module don't work in 'Evaluation' period. The module needs to be activated.
  • Verify that all installed software is compatible with the device and the version of LabVIEW being used. LabVIEW Real-Time Module and LabVIEW FPGA Module should be the same year as the version of LabVIEW you're using.
  • If the LabVIEW Real-Time Module is currently installed and activated, please try repairing the module with NI Package Manager .
    • If the issue persists, consider a full reinstallation of the NI software.
