Modular Data Acquisition
High-Performance Test
Some data acquisition boards and signal conditioning units have a built-in CJC terminal, which is a temperature reference on the board used to calculate and remove the unwanted voltages. If you want to use an external reference for the CJC source, check the use the DAQmx C Reference help to see if the C Series temperature module supports this type of sourcing.The CJC also only effects the output value for temperature, the voltage will not be effected. Therefore, it is possible to create your own CJC calculations if needed.
