PDF File not Created when Exporting from DIAdem
Updated Feb 23, 2026
  • DIAdem 2017 SP1
When exporting a REPORT in DIAdem using File » Export » PDF-Export…, we select a destination path and enters a filename, then clicks Save.
However, after doing so, nothing happens: no file is created, no error message appears, and the dialog simply closes without generating the PDF. This behavior continues to occur even when attempting to save to different folders or using different filenames.
The issue is caused by a corrupted or incomplete DIAdem installation, which prevents the PDF export module from functioning correctly.This can occur after updates, partial installations, or missing components. Reinstalling DIAdem resolves the issue.
