Use NI-926x AO (Analog Output) as a Source For NI 5782 TRIG Input
Updated May 1, 2018
  • NI-9263
  • NI-9264
  • NI-9265
  • NI-9269
  • NI-5782
Is it possible to use pulse signal from NI-926x analog output as a start trigger signal for NI 5782 module?
You can use NI-926x analog output as NI 5782 TRIG input . Use corresponding scheme from listed below.
Sch.1 Single ended connection
Sch.2 Differential connection
Main restriction here is a maximum output current for NI-926x modules. You can calculate Output Current as Output Voltage / Input Impedance.
Input impedance of NI-5782 TRIG input as height as 10 kOhm, therefore it save to use low current modules as a trigger source.
Note: Do not connect NI-926x Analog Output directly to NI 5782 Analog Input. It may cause current overload
If you need to use NI-926x as a trigger source for other equipment, make sure that it has input impedance height enough to prevent current overload. You can find maximum output current of your module in product specification.
