Compile Linking Error 64-bit NI-DAQmx C Lib File Location
Updated Mar 27, 2025
I get linking errors when I try and develop a 64-bit NI-DAQmx application in C or C++.
Developing a 32-bit application works fine by linking to the .h and lib files found in:
<Program Files (x86)>\National Instruments\NI-DAQ\DAQmx ANSI C Dev\lib\msvc
Using a 32-bit library file in a 64-bit program can cause linking errors. If your program works as a 32-bit application then the linking errors are most likely caused by linking to a 32-bit .lib file.
To resolve the linking errors, replace the references to 32 bit directory with reference to the 64 bit directory for NI-DAQmx.
The 64-bit NI-DAQmx C Lib File Location is:
<Program Files (x86)>\National Instruments\Shared\ExternalCompilerSupport\C\lib64\msvc
​This is a native 64-bit library file and can be used in 64-bit C and C++ applications.
If you do not have this directory on your computer, make sure you selected to install ANSI C support when configuring a custom installation of the DAQmx driver.
