How Do I Share Data Stored in a File Global Variable Between Different Executions?
Updated Jan 14, 2019
  • TestStand 2016 SP1
  • TestStand 2016
  • TestStand 2014
  • TestStand 2014 SP1
I'm using a File Global variable to store data and I'm using a parallel Process Model such as Batch Process Model.
How can I share data between different executions and access the File Global from all test sockets?
In order to share data stored in a File Global variable, you should follow these steps:
  • Open your sequence file in TestStand Sequence Editor
  • Select Edit»Sequence File Properties from the toolbar
  • In the Properties dialog, select the All Executions Share the Same File Globals option from Sequence File Globals drop-down menu.
  • Click OK to register the change.
This will prevent a copy of the File Globals from being created for each execution.
Note that this operation will raise the scope of File Globals to all executions and may result in a race condition.  If you wish to share data between executions without making your File Globals prone to race conditions, consider to use queues or notifications.
