Integrating LabWindows™/CVI™ with Microsoft Visual C++
Updated May 29, 2026
  • LabWindows/CVI
Programming Language
  • C++
This article describes the available methods for integrating LabWindows™/CVI™ code into a Microsoft Visual Studio C++ project. Each approach provides different trade-offs in terms of maintainability, deployment, and development workflow.
This article assumes that you have basic C/C++ knowledge to understand the described methods to integrate CVI code into Visual Studio.
Overview
There are several ways to incorporate LabWindows™/CVI™ functionality into a Visual Studio C++ environment. The appropriate method depends on whether you need to preserve your LabWindows™/CVI™ codebase, align toolchains, or transition fully to a Visual Studio–centric development model.
The primary integration approaches include:
Building a DLL in LabWindows™/CVI™ and Importing into Visual Studio
This approach keeps development centered in LabWindows™/CVI™ . You implement and build your code in CVI, then consume it in Visual Studio.
Workflow
  • Develop and maintain the code in LabWindows™/CVI™
  • Build the project as a DLL (.dll)
  • Generate the corresponding import library (.lib) and header file (.h)
  • Include and link these files in your Visual Studio C++ project
For more details on creating DLLs, see the Creating DLLs in LabWindows/CVI article from the LabWindows™/CVI™ User Manual.
Considerations
  • This is the most straightforward integration method when keeping LabWindows™/CVI™ as the primary development environment
  • It enables clear separation between CVI-built components and Visual Studio applications
  • Requires the LabWindows™/CVI™ Run-Time Engine and any dependent NI drivers at runtime
[Back to Overview]
Using an External Compiler in LabWindows™/CVI™ to Align with Visual Studio
This approach ensures that the CVI-built binaries are compiled using the same toolchain as Visual Studio.
Workflow
  • Configure LabWindows™/CVI™ to use an external compiler (e.g., Microsoft Visual C++)
  • Build the LabWindows™/CVI™ project using this external compiler configuration
  • Use the same compiler settings/toolchain in your Visual Studio environment
  • Optionally transition the build process fully into Visual Studio using equivalent settings
For configuration details, see the External Compiler Support article from the LabWindows™/CVI™ User Manual.
Considerations
  • This approach reduces compatibility issues between LabWindows™/CVI™ and Visual Studio builds
  • It provides a smoother path for transitioning build processes into Visual Studio if needed
  • Still allows you to leverage LabWindows™/CVI™ during development while aligning binaries with your target environment
[Back to Overview]
Replacing LabWindows™/CVI™ Dependencies with Visual Studio-Compatible Alternatives
This approach avoids direct reuse of CVI-specific code and instead focuses on using APIs and libraries that are fully compatible with Visual Studio.
Workflow
  • Identify CVI-specific functionality in your project
  • Replace LabWindows™/CVI™ UI components and runtime dependencies with alternatives supported in Visual Studio
  • For hardware interaction, use NI-provided C APIs that are compatible with multiple development environments
  • Rebuild the application entirely within Visual Studio
Considerations
  • This is the preferred approach when standardizing on Visual Studio as the primary development environment
  • NI hardware drivers typically expose C APIs that can be used directly in Visual Studio or other C toolchains
  • May require refactoring, especially for UI-related or LabWindows™/CVI™ runtime-dependent code
[Back to Overview]
Linking Against Existing LabWindows™/CVI™ Static Libraries
If you already have compiled LabWindows™/CVI™ libraries, or want to reuse shipped libraries, you can link them directly into your Visual Studio project.
Workflow
  • Obtain the compiled static library (.lib) from LabWindows™/CVI™ or NI-provided sources
  • Include the associated header files
  • Link the library in your Visual Studio project settings
Considerations
  • This approach is useful when working with prebuilt or distributed libraries
  • It avoids rebuilding code while still enabling reuse in Visual Studio
  • Ensure compatibility between the library and your Visual Studio compiler settings
[Back to Overview]
Runtime and Dependency Management
Regardless of the selected approach:
  • CVI-built components may require the LabWindows™/CVI™ Run-Time Engine
  • NI drivers (e.g., NI-DAQmx, NI-VISA) must be installed when used
  • Compiler and architecture compatibility (32-bit vs 64-bit) must be verified
[Back to Overview]
Choosing the Right Approach
ApproachBest ForKey Advantage
CVI-built DLLKeeping LabWindows™/CVI™ as primary environmentSimplicity and separation
External Compiler in CVIToolchain alignmentReduced compatibility risks
Replace LabWindows™/CVI™ DependenciesFull VS migrationLong-term maintainability
Static Library LinkingReusing existing binariesMinimal rebuild effort
[Back to Overview]
