The MSVC 2010 compilers are used to compile models for Windows and
PharLap ETS VeriStand targets. Using a broken compiler results in error LNK1123. The .NET 4.5 Framework should be installed with NI VeriStand 2015 SP1 and later because it is required by the UI Manager.
If this article doesn't resolve your issue, please refer to this
KnowledgeBase.
