Accessing DLL Functions in LabWindows™/CVI™ Program Without the Import Library
Updated Aug 19, 2022
I wish to do run-time dynamic linking in LabWindows™/CVI, but I don't want to explicitly include the import library in my project. How can I set this up?
You must use the Windows SDK functions LoadLibrary and GetProcAddress to access specific DLL functions at run-time without including any DLL libraries in your project. The following is sample code for accessing a function within a DLL at run-time.
// File: RUNTIME.C
// Sample code that uses LoadLibrary and GetProcAddress to access myFunction from MYDLL.DLL
// You will need to include stdio.h and windows.h in your project to use this code
#include <stdio.h>
#include <windows.h>
typedef void (*MYPROC)(LPTSTR);
void main()
    HINSTANCE hinstLib;
    MYPROC ProcAdd;
    BOOL fFreeResult, fRunTimeLinkSuccess = FALSE;
// Get a handle to the DLL module.
hinstLib = LoadLibrary("mydll");
// If the handle is valid, try to get the function address.
    if (hinstLib != NULL)
       ProcAdd = (MYPROC) GetProcAddress(hinstLib, "myFunction");
             // If the function address is valid, call the function.
       if (fRunTimeLinkSuccess = (ProcAdd != NULL))
            (ProcAdd) ("message via DLL function\n");
             // Free the DLL module
       fFreeResult = FreeLibrary(hinstLib);
    // If unable to call the DLL function, use an alternative
    if (! fRunTimeLinkSuccess)
      printf("message via alternative method\n");
