Cable SHC68-NT-S & SHC68-68-RMIO Wire Color to Pinout Mapping
Updated Sep 16, 2024
  • SHC68-NT-S
  • SHC68M-68F-RMIO Cable
I have a SHC68-NT-S or a SHC68-68-RMIO Cable, and I want to know how the wire colors map to the pin numbers on the connectors.
The wire mappings for the SHC68-68-RMIO and SHC68-NT-S Cables can be found below.
The wire list document for the SHC68-68-RMIO Cable contains information such as shielded pairs and color codes.
Figure1. Analog Input
Figure 2. Analog Output
Figure 3. Digital I/O
The wire mapping and shielding components for the SHC-68-NT-S vary depending on the cable revision. The mapping for the different options can be found in the links below.
