Cable SHC68-68-RDIO/RDIO2 Wire Color to Pinout Mapping
Updated Apr 16, 2018
  • SHC68-68-RDIO
  • SHC68-C68-RDIO2
I have a SHC68-68-RDIO or a SHC68-68-RDIO2 cable, and I cannot find any documentation which lists how the wire colors map to the pin numbers on the connectors.
The wire mappings for the SHC68-68-RDIO and SHC68-C68-RDIO2 cables can be found below.
The wire list document for the SHC68-68-RDIO contains information such as shielded pairs and color codes.
Figure 1. Group A of the SHC68-68-RDIO
Figure 2. Group B of the SHC68-68-RDIO
Figure 3. Group C of the SHC68-68-RDIO
The wire mapping and shielding components for the SHC-68-C68-RDIO2 can be found below. The ground lines are internally connected on the SHC-68-C68-RDIO2 cable.
Figure 4. Pins 1 to 34 of the SHC68-C68-RDIO2
Figure 5. Pin 35 to 68 of the SHC68-C68-RDIO2
