Get Error Description from Error Code in LabVIEW
Updated Jun 26, 2018
I would like to programmatically call a function in a LabVIEW app .exe with the I32 error code as input and get the string explanation for the error like the Help»Explain Error tool does in the LabVIEW Development Environment.
You can use the Simple Error Handler VI's or General Error Handler VI's message output to view the explanation for a particular error code. See the code snippet below.
