Will my Newer Version of LabVIEW Real-Time be Compatible with the Desktop Utility?
Updated Jun 28, 2018
  • LabVIEW Real-Time Module
  • PharLap
I have converted my PC to a Real-Time system with the desktop utility in NI MAX.
I am upgrading my version of LabVIEW Real-Time. Will I be able to upgrade my PC using the same method?
Yes, you can still use the desktop utility to update your OS. You just have to make sure that the version of the OS matches the version of LabVIEW Real-Time that you have.
