Plot XY Data from a 2D Array in LabVIEW
Updated Jul 1, 2020
  • I have some x-y data in a 2D array that I'd like to plot in LabVIEW. What do I need to do to plot my data?
  • Whenever I connect an array wire directly to a XY Graph, I get an error telling me that I've connected two terminals of different types.
In order to plot x-y data in an XY graph, you will need to convert the data into a cluster of the X and Y array data. The snippet below will allow you to use an XY Graph to plot a 2D array in LabVIEW.
  1. Start with your data in a two dimensional (2D) array
  2. Use the Index Array function to separate the array into two one-dimensional arrays -- one containing x data and one containing y data.
  3. Bundle into a cluster which is the expected input type of the XY Graph function.
Refer to the XY Graph Data Types VI in labview\examples\Controls and Indicators\Graphs and Charts\XY Graph for an example of graphing XY data.
