Effect of Calling UnloadAllModules in TestStand on Other Tests Running with LabVIEW Code
Updated Jan 18, 2019
  • TestStand
In my test sequence I am programmatically calling the UnloadAllModules function to unload the LabVIEW code modules. I also have other tests running in parallel that are using LabVIEW code modules. Will calling UnloadAllModules have any effect on my other tests?
Calling the UnloadAllModules function in a step of any sequence that is running will unload all LabVIEW code modules currently in use by every test that is executing within TestStand. Calling this function is not recommended for parallel and batch process models, where unloading of all modules would affect every execution.
