Can I Connect a cDAQ 9171 Chassis to a Network?
Updated Apr 11, 2018
  • cDAQ-9171
I have a cDAQ 9171 Chassis I wish to share over the network using a USB to Ethernet adapter or a switch/router with a USB port, is this possible?
This is not possible. CompactDAQ Chassis with USB connector were not designed to handle network connectivity as CompactDAQ Chassis with Ethernet connector does.
