Can't connect DIAdem to DataFinder Server
Updated Apr 23, 2018
  • DIAdem
  • DataFinder Server
I'm trying to connect to our DataFinder Server to DIAdem. I can ping the server but the connection times out when testing the loaded configuration in DataFinder. How can I fix the connection problem?
This problem is due to the firewall blocking the ports in which DataFinder uses. There are 2 options to get around the problem:
Option 1
  • Install DataFinder Server Edition. This adds the permission to the firewall rules to connect DIAdem or other DataFinder clients to a DataFinder server.
  • More information regarding DataFinder Serve Edition can be found here
Option 2
  • If you do not wish to install DataFinder, you can configure the firewall settings manually.
  • Step by step guide on how to configure your firewall manually is available here
