If the PXI controller is running NI Linux RT, you need to install the Linux drivers for the Intel Ethernet controller in order to detect the PXIe-8238/40.
The module is not supported in Pharlap RTOS.PXIe-8238 and PXIe 8240 are only officially supported in Windows. To have PXIe-8238/8240 running in Windows, the following software is required:
