LIN Signal Degradation with NI XNET in LabWindows™/CVI
Updated Apr 16, 2018
  • USB-8506
  • LabWindows/CVI
  • NI-XNET
Programming Language
  • C
When I test my NI LIN device with a LabVIEW XNET example, I see a clean LIN output signal. However, when I test my LIN device with a LabWindows™/CVI XNET example, the signal is attenuated and causes intermittant communication failures.
The NI-XNET shipping examples are not identical in LabVIEW versus LabWindows™/CVI. The LabVIEW XNET examples have the Interface:LIN:Termination property enabled by default to terminate in software, while the LabWindows™/CVI XNET examples require either hardware or software termination.
