Why Does LabVIEW 2015 Installer Show a Driver Error?
Updated Jun 22, 2018
I am receiving the following error regarding some drivers during the installation of LabVIEW 2015 SP1:
The LabVIEW 2015 installer shield gives you the option of installing hardware drivers during the installation process. This specific step is intended to apply just when you have the device drivers CD, therefore if you do not use it you may receive this error.
However, if you are not planning to use these drivers you can ignore this error since it will not affect the normal functionality of the version of LabVIEW you have just installed. Additionally, if you want to get rid of this error you can disable the device driver installation option at the beginning of the installation process. Refer to the following image.
