Adding Vectors to Inports & Outports in a VeriStand Model
Updated Jul 2, 2020
My model requires I use vectors as inports & outports. How do I configure them in VeriStand?
You can configure the inports and outports as vectors in the Add Simulation Model configuration window in VeriStand. In order to open the window, open the System Definition File, expand controller and right-click Simulation Model like shown on the image below.
Once in the configuration window, navigate to the appropiate tab.
Vector channels are only for connecting between models that use a same sized vector. If you are looking to use a control, indicator, calculated channel or any of the VeriStand options available, Scalar Channel should be selected. Refer to theĀ Recommendations for Configuring Models link for more context.
